Installed some gel overlays from TFB Designs the other day... pretty happy with the way they came out. A fairly inexpensive way to make a subtle difference. I went white with carbon fiber, it matches pretty well.
I drilled my hubs and brakes myself while still on the car using a drill jig. On a scale of difficulty I'd say its around a 5.5 out of 10. It's a long and tedious process, especially after breaking (2) 1/2 inch drill bits under 60 seconds while on my last hub.
I'd say each hub took 2 hours on average to drill. It was a nightmare for me but it was worth it!
The factory wheels are kind of useless already since so heavy and not very wide, 17's bad size for this car, should of come with 16x8 and at least 5lbs less weight per corner.
Active Shift Designs Gas Pedal Spacer (in red) & Boomba Racing Dipstick Handle (also in red).... matches all the other engine bay bits by Boomba--throttle body spacer, intake manifold spacer & all of the fluid caps....
