I currently have a Mountune silicone intake hose and K&N panel filter with a Bigmouth ready to install soon.
To me, once ram air comes in to the equation, v-dyno is the way to compare because a stationary dyno will have near zero ram effect. The hose might not do anything except look better but I like it. The K&N with Cobb tune seems to do just as well as the Mountune airbox system.
One thing that has been shown with tubular metalic intakes is heat soak. Stock seems better for that.
The 2J clearly works. I think the reason is because it is so short and uses the high pressure cowl air. I'm too worried about noise to go with that intake right now, maybe later.
Stock with my tweaks does not carry any huge disadvantage. It might even be better than CPE when the ram effect is factored in.
Dyno racing is always contentious unless you are personally doing the testing. There are dozens of ways to fluff up dyno numbers so I am suspicious of small changes just as much as large changes. Spending money on small changes is a crap shoot because you never know if the changes are found by cherry picking, dyno fudging, noise or real improvement.
The intercooler and a panel filter are the two changes with real confirmed improvements so you can stop at "stage 2" and get the most bang for the buck or try adding more parts knowing that you are not going to get much measurable return on investment.
The worst case that I can imagine is skimping on the intercooler so that you can buy a CAI and cat back exhaust that do almost nothing. Then the cheapo intercooler will be holding you back more than the other parts are helping you.
