Dropped the subframe and pressed out the steering rack bushings, installed solid aluminum ones, holding off putting it back together while deciding if I want to order in a stiffer front sway bar but if I do it will just be the stock none ST one.
It was the easiest subframe drop and steering rack bushing swap I have done yet.
The puller I had did not fit so I just went to Home Depot and bought a grade 8 , 3/8" x 6" bolt, nut and washers, used a 36mm socket and they came half way out then ran out of threads do took it apart and put a smaller socket on the finished the job. The bushings pressed out so I really did not need a grade 8 bolt,I could of bought a cheaper bolt with longer threads and not needed to do it in two steps, it only took a few minutes to pop all three bushings out.
