Installed CP-E cold side charge pipe after I heat wrapped the whole thing which took a couple of extra hours.
It also took extra time to work around the DIY custom Mishimoto radiator, modded stock fan, oil cooler, big oil filter(had to go back to stock size unfortunately) and the DHM big IC, had to cut an inch off the silicone coupler.
It came out great but lighting and so many parts in the area made the pictures hard to take so will do more later when I have more ambient light to work with.
I really like this charge pipe as nice and low weight being made from one piece of mandrel bent aluminum, NO SYMPOSER port, and a welded in bung for the WMI system I am installing, dang nice part all together.
It is 2.5", will flow much better, looks better, WMI port, Symp delete, race grade hose clamps and silicone couplers, and weighs the same as the stock parts.
All the benefits, none of the fat
