I installed mine today, and after one small hiccup that wasn't the fault of the new motor mounts (passenger mount chassis bolt hole got cross threaded and gave me some grief), I have put about 40 miles on the new mounts and these are my initial impressions.
* I have the Cobb RMM which has been on since the car was under 200 miles new, and the car had 4554 miles on the odo when I took it out to test these mounts today.
1. These mounts most definitely look and feel more solid and of a much better quality than the stock ones.
2. Install is a relative breeze, and can be done in under two hours with the right tools and basic know how. Instructions sent with the mounts leave nothing to the imagination, and the most challenging part for me was dealing with a poorly drilled out frame bolt hole on the passenger side. I worked through it, but it added an extra 30-45 minutes.Thread ease, patience, repeated cleaning, and a gentle but consistent pressure applied to the bolt is what finally got it to take.
3. Initial startup, SHAKE, SHAKE, SHAKE, SHAKE,........lol. These things are stiff, and as with other stiff motor mounts that I have had on other cars in the past, the initial cold start is always the most surprising. You will feel it in the seat, in the steering wheel, in the gear shift, and really all around the car. You will also hear it, but race car.... It lessens after the car warms up, but you are always aware that the extra noise and vibration are there. I'll give it a couple hundred miles and see how things settle, but the real benefit comes next and to me is worth the extra vibration and noise.
4. The car feels more planted, and shifting gears (especially the 1-2 upshift and 2-3 upshift) are noticeably improved. It was a little vague at times IMO from the factory in the lower gears, but now it feels like a bolt action rifle firing off rounds. I absolutely dig it.......
5. Taking off under hard acceleration is drama free, and shifting in regards to all its aspects (up shifting and rev matched diwnshifts) is improved. If your goal is to enhance the feel of the drive and if you are willing to accept some sacrifice with regards to noise and vibration, go ahead and get you some of these.
