The Colony
Love it! I want one so bad. I'm hoping Mountune has a sale or coupon code soon or for black friday/cyber monday and it shall be mine.
Do it! A few Pointers. I used duplicolor filler primer and matte black. 2 cans each. Sanded with 400 first. Light coats of primer. For pin holes in the fiberglass dab primer to overfill. Take your time. I sanded primer one day. Painted the next. Let sit for a day then installed.
MPA
STL
I attempted to install my Rally Armor flaps, but on the first one (driver's front) the screw didn't fit tight into the inner most push clip, leaving the flap mounted to the clip that felt like it would easily pull the clip fro the liner.
I need to find a bigger screw, or maybe just wrap the screw in some electrical tape, or possibly find some kind of wall anchor that will work at Home Depot.
Rochester
That's weird! Using the provided screws? Maybe get in touch with RA about it - they were super responsive when I accidentally busted off one of the mounting screws on the front brackets. (i.e. when they say tighten by hand - tighten by hand...) I bet they'd hook you up with whatever replacement hardware you needed.
CanadianGuy
Southern Ontario
I used some medium thread locking adhesive on all the screws, this IMO helps.
MPA
STL
ya the provided screws - it just never made it fully seated. I'm sure I can figure something out to make them work
