You will get a CEL for Catalyst Efficiency Threshold, but not much else. You're only running it a short amount of time. I would avoid WOT until you get tuned and monitor AFR to ensure you do not run lean. I assume you'll be putting a defouler on the downstream 02 sensor, as well? Might get some soot buildup on the 02 sensor, but you're only doing a two hour trip, so you'll be fine I think.
Is this a catless downpipe or catted?
