![](http://i.imgur.com/0SdryzJ.jpg)
Fiesta ST Recaro Knowledge Base
So you want Recaros, but you didn't buy them when you got the car?
You're not alone. I'm very interested in swapping Recaros into my car. The bad news is, it's not as simple as giving Ford $1,995 and turning a few bolts. Because of this, I've decided to try and put as much information on these seats as possible into one place. There's a decent amount of info out there on these forums, and I know I'm not the only one interested in something like this. With that said, here we go!
So, there are two real options here... The first is...
Fitting Fiesta Recaros into a car that came from the factory with sport seats:
- In Canada and UK markets (possibly more, if you know, PM me so I can add) Recaros are standard. Confirmed.
- Australia has full cloth Recaros as an option. Same in South Africa. Apparently so does China. Confirmed.
- Seen one confirmed sale of the Fiesta Recaros in Molten Orange for $899 (MMMTRBO)
- If your car did not come with Recaros, you will not have the wiring harness for the seat heaters. This isn’t an issue for me, so I won’t go out of my way to find information, but if I do, I will add it.
- According to MMMTRBO, somebody HAS swapped FoST Recaros into a Fiesta—after swapping the bases (sliders?) onto the FoST seats. This is unconfirmed.
- As far as my research has led me, one CAN NOT buy the seats as an assembly from Ford. You must instead buy each piece individually, and it's going to cost you. The covers alone are $600+ PER SEAT, that's not including any of the actual internal components of the seat, such as the padding.
Fitting Focus ST Recaros into a Fiesta:
- Do they use the same airbags? Potentially have someone with a Focus check the resistance of the airbag and compare it to the FiST.
- Fiesta Recaros do not come in full leather, only partial. FoST seats DO come in full leather.
- The Focus seat rails ARE different, nobody has confirmed whether or not they can be swapped for Fiesta rails. I’m assuming the FoST seat rails are the same part number for the Recaros/non-Recaros, but I will check Tasca and find out. (Holes on the Fiesta rails are ~16.5” across, ~17” in length. Thanks to rooSTer for this information)
- These following pictures were posted, the general consensus is that the FoST seats “seem” a bit larger, but nobody has made any measurements. The next meet I go to, I will measure FoST Recaros and then measure FiST Recaros. Focus Recaros vs Fiesta Recaros As you can see, there is no visual difference between the seats. From an engineering/cost standpoint, I kind of doubt that Ford/Recaro would spend time making two visually identical seats that differ so slightly in size that nobody can tell the difference. I theorize that the FoST/FiST Recaros are actually the same size, and the difference that some people feel is more to do with the fact that the interiors are otherwise difference.
If anybody has anything to add to this, PLEASE post in the thread, or PM me. As many links or pictures as possible, please! There are quite a few questions I have, and I'm going to do my best to get them answered. Thanks for reading!
