- Member ID
- #1403
- Messages
- 988
- Likes
- 295
Santa dropped this Odyssey Extreme PC 680 under my tree so I could relocate to spare tire well. So I thought maybe I had better make sure it works up front before doing all that relocation. Turns out it fits stock battery location, terminals, tie down, etc.
Second pic shows with a rubber shim to secure stock hold down. I ran the bolts and washers that came with it, plus a larger flat washer, into terminal tops over stock connections just for extra security.
OEM battery 2.5 years old now, and I had another use for it, so will run the Odyssey for DD in stock location for a while. At less than $10/lb saved, and ease of installation, maybe it will suit others. Not enough room in stock box to lay it down, that would have been too good to be true.
Having read a lot of lightweight battery threads, including RAAM's here from 2014, seems no one has found an inexpensive way to loose much more weight than this, assuming it works.
16 lbs to go to break 2600 with half a tank of fuel.
