I'm new to the fourms! Couldn't find what I'm looking for with searching so I'd figure I'd post a new thread. I think I posted this in the right place
I'm looking to build myself a triple duty track/street/strip (in that order) FiST. I'm going to start off with a Garrett GT2560R with stock internals at first, then down the road rebuild and add the wet shot of nitrous and meth.
1st Question: I've also considered a GT2860RS or a GTX2860R, but I'm concerned that the extra power with stock internals would start to break things before I get a chance to rebuild the engine (think a year or two to save up cash). Anyone who knows about these two turbos could chime in?
2nd Question: A second concern of mine is after I rebuild the engine and add the wet shot, the N20+meth causes the turbo to pretty much spool to max psi instantly. The idea behind this is to have the happy juice fully engage in 3rd and 4th gear on the 1/4 mile (or maybe 2nd if I can get traction). The bad side of this that it will add a CRAZY amount of torque at the beginning of each gear after up-shifting and I think this would break the tranny with a larger turbo. Anyone know if I'm just being overly cautious or is this a legitimate fear with this platform? I know very little about the transmission.
I think the smaller GT2560R would be a little safer to use overall, I'm in uncharted territory so I've had to do a lot of research by myself. Advice? Thanks!
(Boring technical/setup N20 stuff follows, don't have to read if you don't want to)
Nitrous with Meth allows me to safely run a very high amount of power when I need it while retaining the fun street characteristics of a small turbo. The Meth can be run very rich with the nitrous while still making power and curbing knocking. The idea is to tune it "by ear" with a wideband O2 in the downpipe, starting very rich and slowly leaning it out until I find something I like. WOT sensor plus an rpm window switch cut 100-200 rpm before redline would allows for a consistent delivery of juice. Meth mix would be in the windshield washer reservoir, 15 lb tank in the boot...maybe where the spare tire is. I would wire in an electric safety relay in with a pressure sensor, which would only allow nitrous in if meth lines are properly pressurized. This is to avoid lean hell...also would have two nitrous solenoid valves in sequence for redundancy. In the cabin I shall have a purge button and an on/off switch. Going to put the fogger somewhere after the intercooler for maximum benefits.
