Turbosmart dual port kompact BOV - known issues?h
Norfolk
Hi chaps,
I've been running one of these bovs since April time, noticed my peak boost had dropped down to 22psi recently, removed the valve and found this -
Oem valve refitted and boost restored.. Does appear to have leaked from the o ring that mates against the compressor housing.
JPGC
Middleburg
Hmmm, is the o-ring dissolving, lol. I haven't had an issue so far but I haven't had it on as long as you. I would send this pic to Turbosmart with the explanation and see if the have had other issues that are the same. Also, see if they will send you a new o-ring.
Kidders
Norfolk
It certainly looks that way. My friend runs the same valve and his O ring doesn't look the same, it's like the pressure has been pushing under the O ring and with numerous heat cycles has started to degrade. I always felt the O ring didn't protrude enough from the body compared to the OEM valve and the profile now its been fitted is quite square.
Miami
Technically you are supposed to clean the BOV every 500 miles as per the TurboSmart instructions. If it is just an o-ring I am sure TurboSmart will send you another one asap.
Kidders
Norfolk
500 miles? I can do that in a week! I've seen service every 6 months which seems more realistic.
Miami
Yea me too! I am nearly certain that is what the instructions mentioned. When I get home I will double check.
Kidders
Norfolk
Did you just unscrew the top or did you remove the entire unit?
The picture is the whole unit in my hand, it's the base that bolts onto the compressor housing. The O ring is not part of the moving assembly, it's meant to seal the body against the housing. All other o rings are in perfect condition. The valve was also torqued up correctly too.
Miami
Oh shit, ok. That part is definitely not supposed to wear like that then. I thought you were talking about the part immediately under the cap that unscrews/tightens.
Kidders
Norfolk
The o ring under the piston is perfect, there is another sealing ring on the screw on cap ,again good condition. I've never seen an o ring do that before, and the best explanation I can think of is pressure blowing between the body of the valve past the o ring , enough to cause a small leakage of boost under sustained load/pressure, I always felt the o ring didn't protroude enough compared to the oem electronic valve.
MOFiST
Adelaide
I'm interested in what Turbosmart's response is to this. Perhaps a defective o-ring? Or perhaps a design flaw? You sound like you know what you're doing. I was actually weighing up getting one of those but might hold off for now.
Kidders
Norfolk
I would say the plumb back is a good option, it's easier to set up (i.e it doesnt need any setting up at all!) and the recirc noise through the induction sounds just as good IMO.
I've checked over the valve again, and it has been fitted for 6 months, mileage is not mentioned by TS when it comes to servicing the valve. In that time, I have covered 6000 miles.
The piston has been removed, it is of brass construction and one assumes that its machined to match the internal bore of the housing, which is black anodised throughout. This tight interference fit allows it to seal. Spring length has been checked and meets the correct 72mm.
There is plenty of scuffing to the piston wall all around the circumference, which is cause for concern, and another area that could be preventing it from holding boost. Because it also vents to atmosphere, any 'blow by' of pressure around the valve will go straight out the port, and its feasible we have been losing pressure here, as well as the main O- ring on the body.
I will say what Turbosmart have to say about it. I've been more than happy with the valve noise and performance but over time, wear and tear does seem to have taken it's toll.
Kidders
Norfolk
I did some more testing this afternoon, just a simple pressure test, this was on the vacuum side of the valve so blowing compressed air up to 25psi through the take off, low and behold it starts leaking from around the piston from around 18psi, which is why my car wouldn't hold boost properly under load...Worth looking out for.
Kidders
Norfolk
Look at the Maintenance section.......
http://www.turbosmart.com.au/wp-content/uploads/2013/10/TS-0203-1061-KT-DP-SHORTIE.pdf
The Plumb-Back doesn't appear to be serviceable, but it could have the same issues. I just ordered a Plumb-Back this week, so I guess I'll find out next summer if it wears out.
Plumb back should be fine, the piston wont be exposed like it is on the dual port, open to the elements. Personally I don't think its practical to remove the valve every couple of months, strip it down, lubricate it , fit new o rings and refit. Plumb back should be fit and forget, hold higher boost and respond quicker than the stock item.
JPGC
Middleburg
I have the dual port and servicing it every 6 months is no issue for me as I'll do it every other oil change. I have a couple extra sets of o rings for it as well as the recommended lube to service it. I'm the type who likes to tinker so it's right up my alley, I guess, lol. Adjusting it after each service should be fine as well as I will mark it and fine tune it from there. Fortunately for mine, the best setting for it is almost the loosest setting for it.
Kidders
Norfolk
Pleased its all ok for you. I'm gutted it ended up being the cause of my boost issue as I loved the sound and when it was first fitted, its definitely held the boost better top end compared to the OEM.
Our UK cars are much more sensitive to the spring tension as we run MAF as well as MAP. I had to set the spring to its hardest setting to prevent it going into limp mode.
JPGC
Middleburg
Yes I know that the UK cars run a MAF setup and are more sensitive. I've been around for quite a while ;-). I was simply sharing my experience....also even on the US vehicles, the dual port isn't everyone's cup of tea. If I was running a UK FiST, I personally wouldn't even bother with any vent to atmosphere and just simply run a full recirculating valve.
Kidders
Norfolk
Thread Starter #19
I wasn't being condescending ;) Just expanding on why the valve was harder to set up. I liked this noise tbh, it went well with the changed harmonics of the hybrid and gave it some character. Now i'm back to OEM valve its a lot quieter on boost, it doesn't have a high pitched howl to it.
Miami
[MENTION=1675]Kidders[/MENTION] can you please measure and advise of the o-ring sizes so I can source them as replacements please? Thank you!
