Tips for installation. I managed to get the nut on the hex bolt no problem. I used a strip of duct tape placed on the nail side of a my index finger. Long enough to extend to the nut without covering the hole. The nut threaded on the bolt in 1 shot.
The installation instructions were
INCORRECT. They did NOT include 2 locknuts in my kit. Just one. Not a big deal but it wasn't accurate in my case. More importantly it was a
10mm nut not a 9mm.
I could NOT fit a regular box wrench behind the plastic to hold the nut. The way the plastic is molded, you will
need a 10mm OFFSET boxed wrench instead. I didn't have one handy. So I tried a socket with my flattest ratchet. I couldn't manage to get it on. There is very little space to maneuver. What finally worked for me was placing the 10mm socket over the nut by hand and holding it with Channel lock pliers.
Thoughts for Velossatech
1) I'm not sure everyone owns a offset box wrench. It would be nice if you could 3D print a small wrench or shallow socket.
2) Fix the fitment issues with the current design. I pressed the Big Mouth into the opening and it's flush. The nut is tightened down and the cowl still sticks up. The cowl cover issue is real.
3) Update the installation guide with accurate information.
"Basic hand tools" is very vague and not true IMHO. Bumper removal requires T25 Torx bits, swivel sockets, long 1/4" socket extensions, etc. List the
actual tools you will need to perform this task.
add Dremel and maybe a heat gun/hair dryer as a recommended tool.
4) Revise the suggested hole size needed to be cut. It's too big. I think the 2.5" side actually needed to be a little bigger. Better yet revise it and include a printed template for the hole and include it in the PDF.
5) If you can print "Velossatech Big Mouth" on it.. you should be able to print "Made in USA". Show some pride.
