Hello Westcoast -
There is a long thread on here where users were in direct communication with Koni, and the last information they received from Koni was that they will NOT be offering the ST-specific fitment -
http://www.fiestastforum.com/forum/threads/3637-My-KONI-Sports-(yellows)-will-be-here-friday!
Long store short, you have to select the non-ST at Redline 360 and then you'll see the Sports for front and rear. Pretty much, the NVH dampener is useless (especially if you're upgrading the struts), so all you need is to ziptie the ABS sensor wire and you're good to go. If you order the front struts (Sport), each comes with a white plastic knob for adjusting, so you don't need to buy any special tools for adjustment. Disclaimer - I have not had a chance to adjust the fronts yet, but the passenger side is super easy to get to. The driver's side has a reservoir that needs to be removed to adjust that one. The tech who did the install said it's really easy to adjust them, but it looks like it'd be easier to do that driver's side if you remove the windshield cowls.
