So I have two VDynos here. Both of these are with my girl friend and myself in the car. Hence the 3000lb. I have 6 others all showing between 325-331. I am using 92 octane from the on base gas station and I am out of fuel In the upper RPMs. I am still new to this vdyno thing so if there is anything you guys can point out let me know. I read this article here:
http://www.evolutionm.net/forums/evo-dyno-tuning-results/619146-how-use-virtual-dyno-properly.html
I have done the smoothing 0, and smoothing 1-6 trick to ensure the logs were good. and these two had the least amount of change from 1-6 with both less than 7hp and 10tq. The road is incredibly flat I have done the back and forth thing on the same road, and results were within a couple hp/tq. the only thing I can think of for my results being inflated would be the weight of the car itself+occ weight.
So go ahead and flame on, that's fine. but the main reason I am posting this is not for the numbers but so you can get an idea of how the power curve is with the DHM EFR Kit. for whatever reason though I cannot get the boost or AFR to post in the graphs.
