Let me give anyone doing this mod a bit of advice from a noob-idiot. I'm a total novice at this mechanical stuff. Follow the advice of smarter minds here and finagle the heat shield to do the install rather than take it off. It will never go back on right again.
I advise you take off the 10mm bolt holding the coolant line on the passenger side, and pry it back a couple inches (it can take it!). Then undo the 8mm bolt below it, the bolt below that and toward the passenger sheet metal side, and the top passenger side 8mm bolt. Jack up your car and get under that bad boy and take off the two 10mm bolts securing the O2 sensor lines on the downpipe heat shield. That will let you get the lowest heat shield bolt (right under the downpipe heat shield. Use one of those 8mm racheting double sided crescent wrenches from Home Depot. Remember I'm a noob, but it's the one with the black ratcheting closed end and an open crescent on the other. It's like 8 bucks.
This will allow you to pry back the top sides of the heat shield to get to the waste gate. Take the advice of others that did it this way and do one side at a time. Doing this allows you mangle the heat shield less and gives you more hope of lining up the bolt holes again and less chance of stripping the threads inside the manifold. I've attempted to reattach mine perfectly after mangling it, and even purchased a new heat shield, and in the end I got 3 bolts installed again in the original shield. My new one just sits at the moment and I have lots of scars and over 18 hours of time devoted to trying to get my heat shield back on to the condition it was. Learn from idiots like me. Don't go at it without reading through this thread and learn from the mistakes people like me have made. The mod is definitely worth it by the way! Surge is gone... But the spring is stiffer so you have to be a little more deliberate with the gas pedal to get your boost.
