Finally the actuator is installed. As suggested by [MENTION=1146]Joszer[/MENTION] I moved the coolant line farther towards the firewall. I didn't insist on getting the shield out, but as I created enough room to get my hands in there I simply worked within that constraint. Not as easy as with it completely off, but I was able to get it back on and bolted (2 top ones only).
Here you can somewhat see that I could get access to the flapper
I would then move the shield back into position to get to the actuator mounting screws. Ends up being a two-step process, but it worked. Here is the [MENTION=3805]Tune+[/MENTION] actuator installed.
Few tips:
- I didn't deal with removing the vacuum hose until the actuator was off the bracket. This makes it easy to access the clip securing the hose. Then don't forget to attach the hose to the new actuator first, slide clip back on AND then bolt the actuator on.
- To set the actuator pre-load, just follow the [MENTION=3805]Tune+[/MENTION] video
https://youtu.be/_UDVTVmQ0xw
- I used both stock screws to secure the flapper, as this would mate up well with the clip
- I also used the stock actuator heat-shield, not sure if needed, but figured it wouldn't hurt
- I discovered that if you have a nice size piece of cardboard under the engine area and you drop a screw or other small object, if it falls all the way thru, you can most likely just pull the cardboard out and pickup the fallen object, without having to crawl under the car
Thanks again to those who reached-out with help.
Now off to get some logs for [MENTION=3805]Tune+[/MENTION].
Enjoy your Sunday and have a great week.
