Installed mine last week. Very happy with it. As with the rest of you I want to destroy that heat shield. I did get it back on with only one bolt missing, I just couldnt get it to line up. Gives me a good product idea though! ;]
I just so happen to have access to a dyno.... the end result was not meaningful because the extra boost was creating a throttle closure problem.
Even so, boost at 6700 rpm went from ~12 psi to about 16 psi.... However, the throttle angle at that point was 50 degrees. I am easily seeing >20psi at redline on the street. This product works! I have seen up to 25.6 psi as well on the street. Now to hone in the tune...
Thank you Adam!
