Let me rephrase this a bit.
IF, you can find the right tire to fit your needs in 16", which I will gladly help you with, no charge, the 16x8 is the best wheel size for this car for performance aspects on a road race track, autocross, good weather mountain run, even looks.....
IF, you need a great all season tire and still want it a bit wide they are available that will work on this wheel but you could do well on a 7" wide wheel as well.
IF, you are into rally, rally cross, just want snow wheels and tires, not the right wheel you need, go narrower, go 15, etc.....
IF, you are into road racing, autocross, etc and can DIY a BBK or live with stock brakes, 15" is better in many situations but 16's are still viable depending on your specific needs.
Again the main issue is the bigger wheel is better mentality, many merits, mostly style and we are stuck somewhere in the middle of tire and wheel choices that fit and do the best for our intended needs.
