If you are serious about real performance or even just the look....go to this thread and add your name to the list![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
http://www.fiestastforum.com/forum/threads/6837-Interested-in-16x8-Pro-Race-1-2-wheels-Reply-here!
16x8 benefits.
1) 17" factory wheel diameter limits the amount of sidewall that can be used which reflects directly on ride quality which also directly reflects on wear and tear on the suspension and body structure over time, 16" wheels can solve this issue with the right tires.
2) Few tires made which fit the car properly if you want a wider tire, which should include a wider wheel for optimum handling, some wider tires available that are not to tall.
3) Generally you can save some weight depending on the wheel and tire combo or at least maintain the same weight and still have wider tires and more sidewall, both pluses.
4) Better high performance all season tires to pick from in 16" vice 15" and both are better than 17's as a very stiff tire does not grip as well in adverse weather.
5) 16" should fit over the current BBK's though might not be tested yet, 15" does not fit.
I have 205/45/17 Michelin PS-3 A/S, the best high performance all season tires made and very expensive at that(in reality a 3 season tire as not to great in snow, the Conti higher end tire is better in snow but not nearly as good in the summer.
I am going to loose hundreds of dollars and sell them and go to 16's so I can either run the Mich PS-3 A/S in that size or the BFG Comp 2 AS which I am leaning towards though on 16x7 as I cannot get any wider wheels in the proper offset with the 4x100 bolt pattern unless I spend a fortune on forged wheels for the winter, not going to happen.
My Rival S tires in 225/45/15 on 15x9 wheels have incredible summer grip but shockingly better ride and less noise than the Michelin tires in 17" that I have back on the car for the winter.
PCA, Kudos for offering to bring us the 16x8 1.2 wheels, very high quality, very reasonable price, perfect fitment for the car.
http://www.fiestastforum.com/forum/threads/6837-Interested-in-16x8-Pro-Race-1-2-wheels-Reply-here!?goto=newpost
I would order at least one if not two or more sets but I have 18 other wheels in the 4x100 conversion so not going to work for me![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Any questions please ask![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Rick
16x8 benefits.
![](http://imageshack.com/a/img538/3478/RkPa6R.png)
Rick
