Hi all, longtime lurker (2013?), new owner of bone-stock CPO 2014 Oxford White with Recaros and Nav.
At only 4 days and <100 miles of ownership I find the FiST to meet or exceed my expectations in every way, especially every corner I can take "at speed" (taking the non-direct route to and from work helps )
Beyond decent tires at the right pressures* and street-friendly alignment** and short of aftermarket LSD, are there any other chasis modifications than can mitigate outside wheelspin?
Specifically, I'd like to tap itno the community wisdom on anything related to the following:
-The stock setup already "feels" completly flat, so bigger antiroll bars won't help?
-Maybe upper and/or lower, front and/or rear chassis bracing?
-The ONLY thing I don't love about the chassis is the "jittery" rear end in long sweepers, mostly due to the "very" short wheelbase I am not used to or is there an opporunity to adjust damping, spring rates to "stabilize"? And mitigate outside wheelspin in the process?
-Whatever else I am not thinking of...
Or is this merely a case of PEBSASW? (Problem Exists Between Seat And Steering Wheel ) aka "Straighten out first, moron"
*I'm looking at swapping to 16x7 lighter weight wheels and 205/45/16 tires (maybe RS3s?) when the excellent (to me) stock REs are done.
**My FiST is "just" a daily driver, but I like putting my foot down midcorner, not interested in negative camber that makes cornering awesome but causes premature tire wear. (What's a good middle ground for the FiST that does not compromise the overall EXCELLENT stock chassis setup)
Apologies for the very dense post, kind of excited to join the community for realsies!
