how beneficial are these for daily driving? Granted, all my other mods def arent necessary to drive back and forth to work but have noticable affects during the experience. are these made more for track/ autocross?
If you've ever driven the vehicle aggressively for long period of time, you will notice the pedal feel begins to feel vague and you experience fade after a while. This is due to the Fiesta having brake regulated torque vectoring which is continually using your brakes whether you are on the pedal or not. The benefit about our set-up is that it is something you will be able to bolt on and leave in place. You won't have to take it on and off each time you visit a track or decide to drive aggressively. You will experience less fade and more confidence in your braking through most types of driving by running this set-up.
Autocross may not get enough heat into the brakes fast enough for it to matter or for you to get fade.
They are def worth a shot on the track for sure. Who knows what we'll find.
I think they will be PERFECT for hard street driving. I can get fade on some of my hard drives.
Hard street driving, back roads, road courses; you name it!
Will the OEM disc shields need to be removed for these?
In order to experience the most effective level of cooling, the OEM dust shield should be removed. They are only held on by two bolts. We are also working on our own dust shield that can be used to work in conjunction with our deflectors.
Jep, would not work if the Air only hit the Shield.
I hope that these will fit on the EU Spec FiST, because there is no Product like this on the Market here :/
From what I can tell, these should be good to work on Euro spec Fiestas!
