Quick UPDATE:
Took the car to the dealer today to have them do a proper flush (using the ABS scan tool) to see if this would fix the pedal issue. Car is still behaving strangely with the pedal sink. Service advisor drove the car after the brake flush and thought everything seemed normal. I will not be back to that dealer for any service.
So, just to recap the issues I have:
- Did full pads, rotors, and brake fluid bleed (using Motive power bleeder) on 5/12. Had to rebuild front right caliper due to rusty piston allowing fluid to leak past seal. Pedal felt spongy and had a little bit of sink after all of this.
- Activated ABS in gravel lot and re-bled the system. Not much difference. Decided to take car to dealer to have them do a flush using their scan tool
- Dealer does a full flush and brake inspection 5/18. Stopping power is a little bit improved (probably more due to pads bedding in), but the crappy pedal feel and sink is still there. Pedal will SLOWLY sink at stop lights, and with the car on, I can pump the brakes which GREATLY reduces the travel and also at the same time GREATLY reduces stopping power. Dealer service advisor drove the car around but thought it was normal, told me that pumping brakes while driving is not advised (lol).
I'm thinking Master Cylinder or brake booster. What do you guys think? I may take the car to another dealer to have a second opinion. My car has entered its certified pre-owned warranty phase, so I'm hoping a replacement master cylinder or brake booster would be covered
Thoughts?
