Update on working with Tune+ since installing the upgraded WGA plus utilizing Adam's pro e-tune. I used to have an issue with ignition correction on all 4 cylinders, and each cylinder would follow its own path throughout my pulls, and either advance or go negative depending on who knows why? It was not pretty to look at on datazap, and I was honestly concerned that my car might have even been defective somehow. I have never brought this concern up to anyone (my fault in retrospect), and I was curious how working with Adam might effect this particular issue. My thought process was to let him bring it up or not, and see how his tune effected this one aspect.
For the 1st time since I have been datalogging (I started this past summer) my ignition correction on all 4 cylinders is smooth and in line with one another throughout the entire pull. It looks clean and flows well as other well sorted ignition correction graphs that I have seen via datazap have appeared. Job well done.
Also and according to Virtual Dyno, I am hitting maximum whp sooner in the rev range, and my hp line remains relatively flat once peak hp is reached. It only begins to noticeably dip late in the rev range, which explains why the car now feels like it has power up top as opposed to hitting a wall late in the rev range. Very happy, again......
Ryan
Ryan
