Steve, please post up said emails. I keep all my emails, and I don't have any correspondence via e-mail with you. If I'm in err, please forward the emails to me at
sgoldade@stratifiedauto.com and post them up here. Because I'm usually wordy, I'd appreciate you highlight the area asking for help setting up Aux fueling or E85 use.
I do have some PMs out with you however, asking you about E85 injection noise increasing, and about trying to get Flex Fuel maps enabled in SCT/Cobb, from when we supposedly "buried the hatchet". This is after our Focus ST aux kit was already to market and we sold quite a few. I took a quick glance over them, and I don't see me asking for help, just if you've had noise or could help get some support in the SCT realm for Flex Fuel as Cobb doesn't enable the tables.
I have maxed out the stock LPFP with our auxiliary system for the Focus ST on E85, to where LPFP starts to drop and I start to run lean.
All of my data is publicly available here, whether good, bad, or ugly. Most is from my very own car:
http://datazap.me/u/bugasu/
For example, aforementioned log, which gives you no clue that I'm running E85, but you can see LPFP drop from my target (92psi) to 80psi, HPFP drop out, and the car starts to run a little lean.
http://datazap.me/u/bugasu/log-1435108184?log=0&data=7-13-14-15-16-23-24-25-27-28-29
Or I don't know, this one of me testing out injector limits for high-load RPM with E85:
http://datazap.me/u/bugasu/e85-injector-limits
I don't see your logs anywhere either come to speak of it. Just pictures of LiveLink with a few things plotted. I've tested this on my own car, Alex on his, and I've remotely tuned someone else to the E85 limit as well on a 6758. We all run out of LPFP in about the same airflow region.
Our systems are fully E85 compatible, and while I'm not running E85 currently (usually stay around E50 as that's all I need to hit MBT and it gives me more fueling headroom), I've done it plenty enough to know how to do it.
I don't know why you dislike us so much. I have not a clue what I've ever done to "wrong" you, so I'd appreciate it for you to either make your claims publicly about what is wrong with our system, or to move along with being the "only Focus ST running straight E85".
[MENTION=688]Sourskittle[/MENTION], if you have any questions, feel free to post them up. I'll try to answer any questions publicly.
If anyone has questions they'd rather ask in private feel free to email me at
sgoldade@stratifiedauto.com.
