By the way, I have been reading and using rules of different orgs for decades so pretty familiar with interpreting them but sometimes a rule or two is not quite clear so have to ask the director to make sure following them correctly.
Street Prepared class:
Allowed:
IC change as long as nothing cut to fit it.
Bypass valve (see note below)
Down pipe
Engine mount
Not allowed:
BOV or pop off valve change (have to determine if this car is considered to have one of these but more likely ours is a considered a bypass valve which is legal)
Your class is Street Prepared unless the BOV/bypass is considered BOV then is so it would mean Street Modified which is a pretty wide open class.
I do not always agree on some of the rules but they are there to keep things as even as they can in each class and stock the ST is likely to be bumped up a class next year, any dominant car normally is.
My advice, mod your car anyway you want then run the class it falls into and accept whatever results you get.
BUT, race against all the classes in your mind, I always do that and have great fun
Allowed:
Down pipe
Engine mount
Not allowed:
