This will undoubtedly start a big argument but, what the heck. Bring it on.
I recently changed my air filter......put in the brand new factory paper filter that came with the car. I removed the K&N filter
I installed in the car's first week of life. That was in June 2014. Thought I better check it......duhhhhh. Anyway it was only moderately soiled, but I took it out and washed it......and replaced it with the OEM filter to let the K&N dry thoroughly. While I had the factory airbox open, I noticed that it has an inlet pipe running to the front grille.......in other words it's sucking in cold air from outside the engine compartment......as opposed to the so-called "Cold air" setups that bring in the hot air trapped under the hood.
Now I have watched multiple video's checking cold air intakes against factory air boxes.......with dyno results showing zero horse power gain, and in some cases even less horsepower than the factory set up.
I will stick with the factory air box. I believe these so-called cold air intakes are BS and hype. And......frankly my unscientific seat of the pants test for the factory filter versus the K&N is.............the car "feels" quicker with the factory filter.
BTW, I love the car.......just creeping up on 20,000 miles with zero issues.
