Hey guys,
Intake discussions typically turn into massive threads filled with angry discussions backed mostly by opinions. There are a few ways to ensure you are getting a good product. First, purchasing from a trustworthy company with accurate and in depth data. Although I am sure you are aware, skewing dyno data is quite simple and can be done in a variety of ways. Building the trust of an enthusiast community is a challenge, especially when your products perform well and defy typical opinions of intake system power benefits. The second method is through positive independent reviews. Once a product is on the market, normally you will see a few folks post up their opinions. Assuming they are unbiased, we can infer that this member is providing an honest opinion, even if they may be slightly influenced by excitement.
For a product not yet released, obtaining independent reviews can be quite challenging. In the end it is up to the consumer to determine if they trust the company enough to be the forum “guinea pig” so to speak.
We consider our shop Fiesta to be our “guinea pig”. We’ve put a ton of spirited mileage on the car and it’s also seen countless dyno pulls as we tweak product design and enhance each component. Our car is the official test subject for all products hitting our warehouse shelves. In this respect, we expect our customers to have a level of trust that assumes our products will in no way damage or negatively impact their vehicle.
Our Offerings
We actually have two projects going on in relation to the intake system of the FIST. Both are fantastic projects and offer a slight difference in benefits and features. In addition, both products produce power gains, which are completely repeatable.
Option 1: Silicone Induction Hose
• Easy To Install
• Retains Factory Airbox
• 5whp / 10 wtq bolt-on gains
• Factory-Like Appearance
• Inexpensive (Now on Pre-sale, $149.95)
• No additional intake noise
Our induction hose is quite an interesting piece. This component replaces the factory rubber induction hose which features accordion portions to allow for engine flex. As a result, these portions of the hose cause restrictions to airflow. Smoothening the internal diameter of the hose proved to make a massive impact on power output, even our engineering team was a bit surprised. Dyno plot shown below!
Power is made through the low end through 5,500 rpm. Once at the top of the power band, power output is similar to the stock hose. Maximum gains are seen around 3,000 rpm to the tune of 5 whp and 10 wtq, which is where the factory plot seems to dip while our induction hose retains a smoother line. Through most of the band, we are seeing 1-3 whp/wtq which is a nice increase considering you can bolt this on in around 15 minutes (this includes beer breaks).
For more information about our R&D, as well as an evaluation of the stock hose, check out the thread below.
http://www.fiestastforum.com/forum/...sta-ST-Silicone-Induction-Hose-R-amp-D-Report
Option 2: Full Intake System
Prototype Image
• Slightly longer installation process
• Replaces factory airbox
• 6 whp / 10 wtq bolt-on gains (More Power In Top End)
• Bolder Engine Bay Addition
• Increased Intake Volume, Improved Induction Noise
Our intake system is still in the development phase and is for a bit of a different customer. Your first question may be in regards to power output. Why is it only making one more whp? Take a look at our plot for this system.
The plot is strikingly similar to that of our induction hose. Primary differences are the power gains at the top end, which we can attribute to the removal of the restrictive stock airbox. On average, this system provides an additional 1-2 whp / wtq over the induction hose through most of the powerband. Not huge, but every pony counts.
This setup is for someone looking for both noise and power, and it certainly provides both. This airbox is much less subtle than our induction hose. You can hear it and you can certainly see it when the hood is open. We are wrapping up development here within the next few weeks and will likely launch a discounted pre-sale.
For full details on the R&D process, check out our thread below.
http://www.fiestastforum.com/forum/...for-the-Fiesta!-ST-Performance-Intake-R-amp-D!
That should provide some basic insight into the results we saw with the components designed by our team. Both are great products and nice additions to the ST. Let us know if we can answer any questions about either component.
Thanks
-John
