@sekred&sourskittle I picked up a mishimoto j line black ic yesterday to. After using my discover points and a $50 amazon gift card it only cost $165 shipped. I can't wait to get it installed. I'll be anxiously waiting for more installation info sekred as well as any tips/tricks to make it go smoothly. As that guy on the other forum didn't really post much info.
Bargain price envyist.
As for installation of the IC it turned out to be a good fit for me. Bear in mind that my Euro ST runs a different front crash bar.
In regards to installation advice, preparation is the key for a smooth job so have all the extra bits you need. Nothing worse than running to the Auto shop 3 time in one day.
Have a plan on how you will mount the IC itself. Brackets, bolts, welding?.
Before I began disassemble I took some measurements.
Inner edges of the front bumper to the face of the OEM intercooler. The bumper is curved so there is less clearance at the outer edges.
I had the vehicle sitting on stands when I did the job. Before I remove the bumper I measure from the lowest position on the bumper to ground. This gave me a Idea of where the Mishi IC was sitting in relation to the bumper lower edge when deciding on its height position.
Before removing the OEM IC I measured how far it was sitting forward of the front face of the cash bar. When I mount the Mishi IC, I knew how far I could position it forward before it would touch the bumper.
The only other bit really was the 90 degree piping, cutting it to length once the Mishi IC was mounted and getting beads rolled on the edges so the hoses don't blow off.
The other thing need addressing is the short front undertray that cannot be refitted. Its in two parts. The front horizontal section and the rear curved vertical strap that hangs down under the engine. Once you remove the front section, this vertical strap still bolts to the inner guards but now has no support in the centre and flops about.
Going to have a look today on sorting this out, shouldn't be to difficult to make a support of some kind.
Cheers
