If you pop off the boot and side trim panels you can get the the nuts at the base of the shifter mech.
Tough a bit awkward to work on you can remove them, lift up the unit, add the spacers and nuts mentioned and bolt it back down with whatever lift you wish.
I did have to relocate a sensor mount from over to under the cables, it was not hard to do.
I am 63, many injuries, disabled, arthritus, it was a fairly difficult task but if I can do it most anybody can
