Steeda Fiesta Short Throw Shifter
Carson City
If you pop off the boot and side trim panels you can get the the nuts at the base of the shifter mech.
Tough a bit awkward to work on you can remove them, lift up the unit, add the spacers and nuts mentioned and bolt it back down with whatever lift you wish.
I did have to relocate a sensor mount from over to under the cables, it was not hard to do.
I am 63, many injuries, disabled, arthritus, it was a fairly difficult task but if I can do it most anybody can;)
North West
Is the shifter really that bad? Can only say I have missed a gear once at the track, and per the log I had it back into gear in a half a second.
Universal City
I want a short shift kit just so I can run a shift lever extension without making my throws longer, but I don't think any of them offer enough throw reduction to do it. I've driven a lot of BMWs with AKG, and would love something similar for my ST.
JPGC
Middleburg
If you run the boomba short shifter and the trans adaptor (boomba, mountune, FS Werks, etc), it shortens things up a lot....enough to still have short shifts with an extension.
Oconomowoc
Well...that may be the way to go then. Looks like a bit of work,but if it pays off...
Carson City
When shifting 100+ per lap in a 20 minute session a shorter through and more precise engagement, placement, etc become very important. When a car is modded to be considerably faster than stock, race tires so faster into and out of the turns, going all out, keeping both hands on the wheel as much as possible, then it becomes critically important which encompasses safety concerns at that point.
