Pondering the range of results posted for OEM brake pad and rotor wear on track and reports on various big brake alternatives.
My experience is that leaving nannies on while driving hard on track will toast brakes, rears faster than fronts but both used up fast.
With nannies fully off, rear brakes are ok, rotors below 750F and calipers below 250F based on my two temp test days at different tracks.
Fronts are another story. Hard tracking will use up a lot of front brake via traction control even with all nannies off. Harder you throw it around, faster fronts wear. I was so aggravated by TC intervening on track days that I sprung for Quaife before getting better brakes. Now maybe I do not need better brakes.
It would not surprise me if OEM brakes and pads are fine for tracking with a LSD, at least with DOT tires.
I ran my temp tests after installing Quaife LSD. Inside rotors ran over 1250F Sebring and 1000F PBIR, outsides ran about 250F cooler. Right front ran hotter at Sebring, fronts equal at PBIR. OEM pads worked better than Hawk street/track pads, no fade, no visible wear (on 1/2 a dry track day, cannot count rain tracking).
The key for us trackers is how much front brakes are being used for TC. We really need a way to log this (Cobb?). I know TC is still active with the Quaife, cannot tell how active. I am getting power down out of turns so much better than before I am delighted with the mod, so front brakes definitely less involved with LSD. But we need data.
Anyone know how to collect TC data? Or some approximation thereof?
If we had TC data, maybe a lot of the front brake mysteries reported in forums could be better understood.
Thanks
PS. I hope I read wrongly that Focus RS uses the same TC we have but on all 4 wheels. Great system for street driving, lousy for track.
Thanks
