Installed it last night. Looks awesome installed and super clean! Props to Sara and the Mishimoto team for an awesome product and being responsive! New product launches are not easy. Hopefully other users can get their orders fixed quickly.
Took less than an hour to install. All the problems I had during install were not related to OCC/Mishimoto design, but a failing of myself (torque wrench busted, difficulty removing the tie holding the OEM hose, bike repair tools to secure the OCC to the bracket). The only concern I have is that the hose running to the inlet hits the side of a bracket (see below). Going to keep an eye on this long term, but I'm assuming it's not going to be an issue.
It's definitely near impossible to get your hand in the right position to apply enough torque to remove the bottom of the OCC. I didn't attempt to loosen since the engine bay was still a bit warm at the time of install. I don't know if I would suggest the drain kit because the belt is right next to where it drops down. Removal of the entire system shouldn't be too bad though because of the QD connections supplied (awwesssoommee). I've never had an OCC before, but to me this is definitely a super clean install because of the included hoses.
If you're like me and worry too much about your own ability to install, it should be easy to put the OEM hose in temporarily and leave the OCC in place as a temporary solution.
AGREED! (Though I still think it would look a little better if they ran the same direction relative to the hose
Everyone likes pictures, so here's a dump with some before/after
