Beat The Heat! Mishimoto Intercooler R&D!
mishimoto1
Hey guys,
Another project from the folks here at Mishimoto! Check out the details on our blog or posted within this thread!
http://engineering.mishimoto.com/category/ford-fiesta-st-performance-intercooler-2014/
Beat The Heat! Mishimoto Fiesta ST Intercooler R&D, Part 1: Big Plans for a Little Car
We?ve discussed R&D for many of our typical product segments for the Fiesta ST. These include our in-progress aluminum radiator, our already released catch can kit and oil cooler solution, as well as our nearly complete intake system and exhaust components (both cat-back and downpipe). Our company is also known for its strong line of heat exchangers, so we certainly need to see what can be done about the undersized stock intercooler on the Fiesta.
Heat is a big enemy of the Fiesta, as many have already discovered during track driving. High oil temperatures, high coolant temperatures, and a heat-soaked intercooler all commonly occur after short periods of aggressive driving. We?ve been actively tackling both the coolant and oil temperature concerns in other development threads, but now it?s time to lower the intake temperatures with an upgraded intercooler.
Stock Intercooler Evaluation
You?ve probably seen the stock Ford Fiesta ST intercooler on the forums or Internet when folks are replacing the laughably tiny core with a much larger piece. We need to evaluate the size, shape, and components so we can begin brainstorming ideas for our own design.
First, a look at the cooler in place with the bumper removed from the Fiesta.
Stock Ford Fiesta ST intercooler
Just under the massive stock crash beam sits the stock Ford Fiesta ST intercooler. All airflow reaching the bottom portion of the radiator must first pass through the fins of this heat exchanger.
A few clamps and a couple mounting bolts later, the stock intercooler was off the vehicle.
Stock Ford Fiesta ST intercooler removed
Take a closer look at the end tanks on the stock Fiesta ST intercooler.
This style of intercooler is typical of modern Ford turbocharged vehicles: a thin tube-and-fin core mated to plastic end tanks. The core is crimped to the end tanks, and an inner rubber seal prevents air leaks. The tanks feature a mounting peg on each side as well as a mounting point for hardware to attach the cooler to the radiator core support. Fairly simple design.
One would think Ford designed this cooler to support the ST in stock or lightly modified form. While the cooler performs well during normal driving conditions, our old friend Mr. Heat Soak is a real possibility during long-duration idling or repeated high rpm pulls. This is the case even on stock vehicles, which is pretty disappointing.
Not to worry though, we will have an ideal solution worked up in no time!
Prototype Design
Designing our prototype will be a somewhat lengthy process. We need to capture dimensions from the stock end tanks to properly incorporate the mounting points and inlet/outlet locations for our cooler. In addition, we need to fit a larger, more efficient core without adversely affecting fitment. Before jumping in, let?s outline a few goals for the project.
Project Goals
1. Bolt-on fitment without vehicle modification, component replacement, or bumper cutting.
2. Improve heat transfer substantially with a larger, more efficient core.
3. Design end tanks with smooth internal flow.
Smooth flow is key to reducing pressure drop across the core of the cooler. Less pressure drop means the turbo is working less to produce the same amount of boost. This can help extend the life of your turbocharger and can also affect throttle response and power delivery.
4. Core height should not be substantially greater than the stock intercooler.
This is a big one for us. The stock cooler sits right in front of the base of the radiator, which affects airflow to that heat exchanger. By retaining the stock height, we can be sure that radiator cooling efficiency would not be reduced even more.
5. Experiment with both tube-and-fin and bar-and-plate options.
This is the fun part. In considering airflow to the radiator, any reduction in flow will hamper the already poor efficiency of the stock radiator. A tube-and-fin intercooler typically allows more airflow through the core compared to a bar-and-plate design. Even though efficiency is slightly less, we will be testing both core types to determine the impact on coolant and intake temperatures, as well as the resistance to heat-soak. We normally go with bar-and-plate options on our projects, so I am pretty excited to see this experiment. The Fiesta ST is the ideal application for this comparison.
6. Greatly reduce (or eliminate) the chance of intercooler heat-soak.
So, we have a tall order for the R&D of this cooler. Easy is not a word I would use to describe this project.
Prototype Design: Core Mock
First, we needed to see what size core we could fit within the limitations of the front end of the Fiesta. We used foam to mock up the proposed core size for our intercooler.
Foam core size mockup
Mockup for Fiesta ST performance parts
After a few adjustments, the core size was mapped out. Size comparisons are shown in the chart below.
This size increase paired with a more efficient core should provide for the heat transfer needed for nearly any power level of the ST.
Prototype Design: End Tank
Now that we had an estimated core size, we could begin designing the end tanks as Solidworks models, which were eventually printed out on our 3D printer.
3D printing Fiesta ST performance parts
After a bit of waiting, which involved hopeful peering into the printer bay, the prototype pieces were complete.
3D printed prototype Fiesta ST performance parts
Looking good! As you can see, the shape of this piece is similar to the stock tanks. One of the primary differences will be the construction material, cast aluminum, which will provide undisturbed airflow and optimal durability.
Coming Up!
That?s it for our first segment on the Ford Fiesta ST intercooler! Next time we will be mocking our tanks into place and finalizing the design of our cooler in 3D! Check out more articles on our blog featuring upcoming Fiesta ST performance parts.
Thanks for taking a look!
-John
Looking awesome so far. This and the catch can are what I've been waiting for the most. The 3D printed end tank looks really cool.
Have you looked at what people are already doing with the J-Line intercooler? You may be able to to some slight modifications to it to make a perfect fit and use the different end tanks. Just a thought.
I think this will be a nice alternative to the J-line. Probably more expensive and smaller core, but the fitment will be just right.
The other thing I like about this new design is that it will fill the intercooler cut out in the bumper cover from end to end. I think this is somewhat overlooked with some of the other aftermarket ICs. If you leave space around the endtanks, you get less ambient air pushed through the cooler itself and more air flowing around it.
M
mishimoto1
Thanks for taking a look Azov! We have another update on this project coming in the near future.
Thanks for the input guys! Yes, we are very aware of the folks using our J-Line unit on both the Fiesta and Focus. That cooler is quite large and efficient, it is rated to around 500 whp. Our goal with this project is a kit directed at the Fiesta, which provides factory-like bolt-on fitment and supports high horsepower ST's. The J-line installs quite well on this model, but still requires trimming of the bumper/grille due to the thickness of the core (3.75"). In addition, we will be tweaking the core to function optimally with pressure/heat generated by the EB.
Thanks!
-John
This is the Mishimoto product I have been waiting for. A perfect fit that balances the need for cooler charge air temps with adequate airflow for the rest of the cooling pack. Very excited to see this progress, I would say the intercooler is one of the most important parts for this car right now.
M
mishimoto1
looks cool (pun intended)
Ah, one of the most-used puns here at the office. Thanks for taking a look!
Thanks Cesso! That's the plan for this one. We should have another neat update coming soon.
-John
Make it in gold. I'll pay double to have the gold color lol.
M
mishimoto1
Were going to hold you to it! Joking. Thanks for the input, one more vote for a gold cooler.
-John
M
mishimoto1
Project update!
Beat The Heat. Mishimoto Fiesta ST Intercooler R&D, Part 1: First Prototype 3D Models
Time for another update on our intercooler project! Last time we left off with a foam intercooler core and some cool 3D-printed end tanks. This update is a bit more exciting!
Mock Up Prototype
With both the tanks printed and our core cut to shape, we could mate these pieces to check fitment of our existing design.
Prototype Ford Fiesta ST intercooler assembled
The tanks feature the mounting pegs and brackets to attach the cooler to the radiator and support.
Once assembled, we installed this on our Fiesta to check fitment of the core and tanks. We want this piece to bolt into position like the stock cooler does, with no modification to the vehicle.
Prototype Fiesta ST performance parts
Fitment was pretty close on this first 3D printout. The core looks like it will fill the area quite well, thanks to the additional inch in thickness compared to the stock cooler. We made a few minor tweaks to the end tanks to improve fitment; these were reflected in our second set of printed end tanks, this time in black.
Prototype Fiesta ST intercooler end tanks
With the revisions to our tanks, we now had a perfectly fitting mock-up prototype.
3D Models
The next step in the process for intercooler design is to create a 3D model of our product. This will give us guidelines and dimensional data so we can construct functional prototypes for on-vehicle testing.
Prototype Ford Fiesta ST intercooler rendering
Pretty cool stuff! You will also notice an additional feature not previously discussed. We are working on a splitter design that would direct airflow through the core of the heat exchanger. More airflow means greater heat transfer, which results in a more efficient intercooler. We will be testing these pieces to ensure that they make an appreciable difference in our results. That will be interesting!
Take a look at the back side of the cooler. Here you can see the inlet, outlet, and mounts for the cooler.
The side view below shows the splitter design and angle.
Coming Up!
We still have a long road ahead of us to complete this project, but we are moving along nicely. The next time we update this thread, we will have a full evaluation and comparison of our first functional prototypes.
Thanks for following our progress!
-John
J2FoRS
Hmm very cool. This idea reminds me of a smaller scale version of one on FocusSTshop. Interested to see your testing with/without.
Looks great and I love getting to read these R&D threads, but I'm curious about the splitter. Whats the purpose of the splitter with the angle going up towards the IC (front to back)? Wouldn't it be more useful to direct air that would otherwise be flowing into the crash bar into the IC? Just curious as I'm new to modding cars.
J2FoRS
Don't quote me on it but I believe it is shaped like that because it will be touching the upper part of the lower grill in the bumper like below the crash bar. Blocking air from travelling upwards through the gap and ending up above the IC/into the crash bar, instead it will hit the splitter and divert into the IC.
that makes tons of sense, I guess most people don't drive around without the bumper. lol
M
mishimoto1
Thread Starter #18
Nice work....thanks for posting! [thumb]
Thanks for reading through our write-up guys! The splitter is in place to pull airflow through the core of the cooler as opposed to around it. The end of the splitter seals with the lower grille of the front bumper. This ensures all airflow passing through this portion of the grille is moving through the intercooler. In theory this should aid in heat transfer, we will see if any appreciable difference is made in terms of temperature data.
Thanks
-John
JasonHaven
Any super rough estimate for when you guys will be going to production?
M
mishimoto1
Thread Starter #20
It is too early to tell at this point. Once we begin to test our prototypes we will have a better idea of what still needs to be done to get this intercooler into production. We will certainly update you as we have more information.
Thanks for your interest in this project!
-Sara
