Being as I have had my Lightweight Flywheel for all summer I can say that when i do take it out around town it is really no different than the heavy factory unit for drivability. My milage clutch release and NHV all were a non issue for me as it was not much different than stock. I will say I never drove it with the stock turbo as it went in with the big turbo upgrade and to me that was a little bit of a learning curve with less spool as early but nothing I could not live with. IF I recall the Spec Unit i have took off about the same weight from 24ish to 10ish lbs and pedal feel is the same and grab and release felt the same.. Hope yours works out as good.. Nice looking unit all steel where as the one I have is Aluminum with a steel friction face on the clutch disk area.
In for the Good results too Im sure you will find bliss also ..
