Boomba Racing Catch Cans - Now Available !
Our catch cans are now officially on sale and ready to ship!
We have two versions, a stage 1 kit which works on your CCV side, and a stage 2 kit that works with the PCV side.
Each stage comes with everything necessary to install the kit on your car. Instructions can be found on our website.
These cans boast one of the largest capacities on the market (over 350ml) and are CNC machined from billet aluminum with no welding.
For the first few days, we are going to be running a discounted price on these cans to act as intro pricing. We will have a spot to enter your forum name so we can see if you heard about the cans here. Take advantage of this pricing now, because it won't last forever.
These beautifully machined pieces of billet aluminum are crucial in any direct injected car. They work to collect oil and moisture passing through your vacuum system and to prevent it from entering back into your intake where it would collect on the back of the intake valves and gunk up the inside of your engine, causing carbon build-up.
The Boomba Racing Catch Can is meant to be easy to install, and easy to service. With a mounting bracket that makes it quick and easy to remove, draining this catch can is super convenient. This catch can utilizes a two stage outlet to ensure that the oil within the vapor going through the can is trapped.
Features of the Boomba Racing Catch Can:
-Holds over 350ml of liquid
-2-step outlet filtration system
-User-configurable inlet/outlet set-up
-Easy-drain NPT plug
-Sight window to see the level of the contents
-CNC machined from billet aluminum [no sloppy welds here]
-Available in natural aluminum, red, black, or blue
-Comes with a bracket that helps to make it easier to mount on your specific project
Purchase links:
Stage 1 [CCV]
Stage 2 [PCV]
Intro video:
[video=youtube;JRMhpFNSfaU]http://www.youtube.com/watch?v=JRMhpFNSfaU[/video]
Install video:
[video=youtube;BCmQ0Xkwp98]https://www.youtube.com/watch?v=BCmQ0Xkwp98[/video]
Purchase links:
Stage 1 [CCV]
Stage 2 [PCV]
Intro video:
Install video:
