Fresh Air for the Fiesta! ST Performance Intake R&D!
me32
fairfield
The 2016 guys are gonna be so excited 1st intake that will work on the 16
M
mishimoto1
New Castle
Thread Starter #109
Our ’16+ ST intake system discounted pre-sale is now live! Check out the details below and let me know if you have any specific questions!
2016+ Fiesta ST Intake Pre-Sale Link
Estimated Ship Date / Pre-Sale Expiration
6/10/2016
Includes
(1) Aluminum Intake Pipe w/ CNC-Machined MAF Section
(1) Airbox w/ Protective Edging
(1) High-Flow Oiled Filter
(1) Silicone Turbo Inlet Hose
(1) PCV Silicone Adapter
(2) Worm Gear Clamps
Mishimoto Lifetime Warranty
Let us know if you have any questions about the intake kit!
Thanks!
-John
Brura22
Clovis
Intake, Intercooler, Exhaust coming soon, and some hard pipes. Yall should start doing tunes and stage packages like Cobb and Mountune using Cobbs AP.
A full stage 3 Mishimoto line for the Fiesta would be badass 😁
Sent from my SAMSUNG-SM-G890A using Tapatalk
M
mishimoto1
New Castle
Thread Starter #111
A full stage 3 Mishimoto line for the Fiesta would be badass ??????
Thanks for the feedback, that is certainly something to consider!
-Sara
M
mishimoto1
New Castle
Thread Starter #113
this may be a dumb question, but will the velossa snorkel worth for this?
The snorkel looks like it's placed on the front half of the intake tract - separate from our box - so chances are it should work fine with our intake. With that being said, we did not have that product on the car when we had our intake installed, so we can't officially confirm whether it wil fit or not. Hope this helps!
Elk grove
As far as intakes on Turbocharged cars are concerned I think the first priority should be looks and sound and not power, and that goes double when the stock system is a cold air unit. Quite a few years back we did some testing on a VR4 where we taped up the entire intake filter except for 1 sq inch. Dyno before and after where exactly the same. Same day, Same Temp, Same DYNO. It only took us about 5 minutes to change the intake. We let the car cool off first and then ran it. Exact same HP. On NA cars it can make a difference but you will see marginal if any gains over the stock set-up. Better off putting in a drop in filter and calling it good.
M
mishimoto1
New Castle
Thread Starter #115
Thanks for your input!
Amplified induction noise is typically derived from using cone filters and a proper box seal, so it's important to pay attention to how the filter shroud/box shields the engine bay heat. The colder the air, the better! These are the steps to take to really getting a great sound out of your intake. And you're certainly right, in boosted applications it makes a big difference because those turbo sounds need to be way more pronounced. So that was definitely a major priority for this project.
Also we actually made a bit of power with this intake! Check out our graph below.
We had fairly consistent gains of 6hp and 10ft-lbs of torque. Keep in mind that this wasn't just one of our best dyno runs. We made pulls until the car produced three consistent plots, which were then averaged. This data will be repeatable since we didn't compare a low run from the stock intake to a high run from our intake.
Hope this helps!
Elk grove
Hope this helps!
Honestly that is an impressive power gain for an intake. Congrats. Can't wait to hear it. Any chance matte black will be a color option? I can't speak for the whole forum but I am a bit past chroming out my engine bay if I can avoid it.
M
mishimoto1
New Castle
Thread Starter #118
Still on for May 20th?
We're actually tracking for a May 16th release! That's next Monday, so keep an eye out!
Much appreciated! Yes, wrinkle black will definitely be a color option, along with wrinkle red and polished. Check out the pipes below!
