Sorry you guys have had trouble with the drain hose. We didn't run in to the hose kinking with any of our installs. Once it's fed down as the can is installed, it hangs really nice. The instructions leave it somewhat up to the installer to decide where they'd prefer it to be located. The hose should be secured with one of the included zip ties so it doesn't move around.
Our test cars have had no issues with the hose we include. We chose this hose because of it's resistance to fuel and oil as well as it flexibility. If the hose was not long and the drain valve not located low or at the end there would be no way to drain it without removing the catch can. Turning the wheels hard left and reaching in through the wheel well is how most drain it.
We've found no other location in the engine bay to locate the catch can that would make it easier to install or easier to drain.
Thanks,
Jamie
Thanks,
Jamie
