Thread Starter
#61
another restrictive area is the fan shroud. (as I can sure someone there noticed already) Instead of us guys that have swiss cheesed ours with drills and deremels, a redesigned one that allows better airflow at speed or even a larger fan would be beneficial to those unwilling to cut stuff up.
What is the point of the shroud design from Ford? If it's restrictive at speed, why design it that way?
Also it allows the stock cooling fan to pull the most air across the radiator surface in traffic or while stopped thus helping to cool it.
We've actually developed a few shrouds with at-speed airflow in mind for both the E36 and E46 BMW. An example is shown below.
A slight amount of airflow is given up at idle conditions, but the advantages of flow at speed are rather significant. We also test these systems to ensure the fan is adequately cooling the vehicle at idle.
We are working on some pretty innovative designs for the Fiesta in terms of a radiator/shroud system of sorts. I can't quite release details/images yet, but we may have something to show in the coming weeks.
I didn't see this asked before, and it may not be feasible since you are already working on a separate radiator and an oil cooler. I think a combination radiator and oil cooler where this is one unit, where the oil cooler is on the bottom of the radiator would work for the stock crash bar as well as for those of us that have the Deadhook Motorsports crash bar. You may want to consider this option. This would be fabricated like your radiators for cars with automatic transmissions. With the radiator mounting holes in the front to mount the Deadhook intercooler, this would work very well, as well as for all other aftermarket intercoolers and the stock IC. I would buy this option in a heartbeat.
That being said, if a market persists for this particular setup, we can certainly consider it as a future addition to our Fiesta lineup. Thanks for the recommendation!
Thanks
-John
