This loose stack is... My 2 1/4" to 3" adaptor, a 1" length of 3", 3" v-band, 3" vband, and another 1" length of 3". All this will get tig welded and handed to the muffler guys. The muffler guys ( like most places ) mig weld. But I don't let them mig weld to v-band style flanges directly. This will connect my 3" customer exhaust with the stock oem muffler right at the back of the car.
https://vimeo.com/179134987
This video shows a few issues. #1 it shows the un-modded return line almost fits, but not quiet. I'll be cutting it and twisting it 30 degrees for 2 reasons. First reason is the oil line needs to rotate that much to help it align with the oil pan return fitting. The other reason is that the compressor housing actually is NOT hitting the axle carrier stay since I removed the stock BOV. It's actually hitting the oil return line hose. Rotating it 30 degrees also move its out of the comp housing's way.
Water feed line barb into stock driver side water line.
Water line barb into the passenger side water line.
Feed line, coolant lines, and the Mack daddy 13T Volvo stock comp wheel, lol. Don't laugh, it's miles bigger than the stock 9T sized comp wheel.
Left home at 6:30am and got home at 9:15pm. Long day...
I cut the inlet down to fit a 3" inlet down to the Volvo turbo, but... The radius on the bend is too wide, I may have to build a custom bend for it. Also have to take the reducer that is 2.5" OUT of the 2JR intake so that is stays 3"from the filter to the turbo :0
I MAYBE able to get away with using a piece of the stock charge pipe as a compressor outlet hose, but it's a long shot.
So many different angles to all this, I have to keep notes.
