Your site quoted $351 shiipped to my door.... Does that include customs clearance?
Unfortunately it does not include customs clearance.
Is the dual catch can still in the works?
At this point we are just presenting the single can option due to how the cans performed in initial testing. We have had a few requests for the CCV side can and did find a small amount of debris in our initial tests so we feel that it is worth a second look. However, there are a few other Fiesta ST products that are we feel higher priority so we will be working on getting those to you first. I will make sure to keep you in the loop as far as development and testing for this can as well as the possibility for another.
Love the custom hose design. Very polished looking kit.
One thing I'm curious about is why you've omitted using a check valve when other companies think they're necessary.
As far as including a check valve in our kit, we feel that the stock PCV unit functions sufficiently on its own. I have heard that some prefer to run a check valve, which you can still incorporate into our hoses if you wish (they measure 15mm inside diameter). Let me know if I can assist with anything else!
It definitely is. Next should be a RMM!
Thanks for the kind words! At this time it is not on our immediate list to do for the Fiesta ST but we will definitely take note that you guys want to see one!
Ordered! I'm already nearing 30k miles, so I like the idea of helping engine longevity.
Absolutely, we feel that using a catch can is an essential modification for these motors as far as preventative maintenance to keep your engine running like new for longer.
Thanks!
-Sara
