Thread Starter
Thread Starter
June 23rd
Well I started by only wanting to get the Mountune Winglets attached and ended up doing more.
Started off by fitting the winglets in place and taping off their profiles. This helps 2 ways. Keeps the glue where you want it and off the paint. Also helps relocate the part once you apply the glue to the pieces.
Driver side had led low beam and cool white high beams passenger is is default. Helper in toe.
[MENTION=678]no-pistons[/MENTION] battery tie down (several bolts have been lathered with anti seize and all turbo lines have been tighten)
Much bigger (2 1/8" orange with rally stripes and shift positions)
Lubricated electrical connections with dielectric greases, especially the block heater.
and of course the [MENTION=678]no-pistons[/MENTION] dead pedal.
long day but well worth it. This weekend will be the rally armor flaps
