Ok, and now some additional thoughts beyond what I've posted in the FoST community-
So far I've really only been messing with timing and evaluating ways to make it easier for me to log and evaluate, and then adjust for. Because the FoST community is already pretty established in their process, I figured I would post my method here and others with ATR can confirm how similar it is/isn't to the FoST. It may/may not be redundant and if it is I apologize; trying to share this data in multiple communities and follow the individual discussion-paths causes me to be more repetitive than I usually am.
First off, my overall process of maintaining data on my laptop. Everyone is going to have their own specific way of organization, but I figured that I would post this as what I'm doing simply because of this one single reason-you're going to collect more data than you would possibly imagine. Especially for those that consider making tunes for multiple fuels, it's very easy to get overwhelmed with the amount of data you're collecting and it becomes even harder to try and remember what was the change in-between this 'datalog1' and that 'datalog1'. If you have tons of time then it may be worthwhile to simply save each log with specific info, but I've literally amassed over 200 datalogs since starting this and that went out the window on Day 1.
First off, here is an image of my desktop. You'll notice that there are three separate sections-programs, data, and supporting data.
Programs and supporting data is pretty self explanatory-one opens up/adjusts/evaluates data while the other is background info for what you're working with. I'm going to focus on the data portion because that's where I created a huge mess initially.
You'll notice that there's the three different fuels plus another folder called Maps. Maps is strictly completed tunes that are ready for upload to the AP3. This usually contains one base (OTS v312) map that I can upload at any moment if I've frustrated myself and want to start from scratch. Everything else is a completed file saved directly from ATR. As of this typing, this is what it looks like inside-
At some point in time I get tired of having a ton of maps in there and distribute them to the related octane folder, which is another system I'll describe....now. The octane folder is where I save data directly from the AP3. Every time I stop to evaluate data and make changes, the AP Manager gets opened up, the datalog files are highlighted to be saved and are placed into a file titled after the tune
from which it was evaluated. So this is what it looks like when I open an octane folder-
So you can see that every time I've made a change to a tune, I simply add one to the tune number and save it accordingly. I'll address that shortly because we're kinda working backwards in showing how I store data, which is the opposite of how it's collected. This folder usually only has the datalogs in it until I move the associated tune file into it, but here is one that's complete-
So now I know at any future point in time that if I want to backtrack or re-evaluate some data, I can go to a specific folder and open it to see the tune that was evaluated and the resulting data from that particular tune. It's not often that I do this, but it can mean the difference of going back one or two files as opposed to starting from scratch on the second day. This happens occasionally when you overshoot a target or inadvertently make an adjustment in the wrong direction, and a lot of times I will delete the entire folder in order to avoid picking back up with it on accident.
So basically, the process goes like this, starting with the OTS V312 map-
1. Load V312 into the AP3.
2. Load V312 into the ECU.
3. Datalog V312.
4. Open AP Manager, highlight datalogs and save them in new-folder V312, located in E89 folder.
5. Open ATR, load V312 map.
6. Evaluate V312 datalogs and make appropriate changes in ATR.
7. Save new map as V313 in Maps folder, proceed back to step 1.
At some point in time I get frustrated with the number of maps in the Maps folder and make a bulk transition from there to the appropriate octane folder, and later the individual map files can be moved and stored into the appropriate folder containing the datalogs.
I also keep a notepad with chicken-scratch that briefly outlines what each datalog was for (i.e.-WOT, hills, load, rpm, 5-minute drive) and brief notes on what changes I made in ATR associated with the tune before saving. That may or may not help you if you have to reflect back on something, and a lot of times I feel like it's wasted time because I can pretty clearly see what's being evaluated between logs. In all fairness, sometimes I add an oddball change that may not be related (KS adjustments, etc) or immediately noticeable in a log, so I suppose it could help in the long run.
Anyways, this is just what works for me and where I'm at through trial-and-error, and something different may work for someone else. All I can say is that I ended up having to trash a lot of data because I wasn't this organized initially, so it's worth considering if you're thinking about before trying to learn tuning.
I'll post some more soon with examples of logs, how I collect them, and my process of evaluation.
