Your welcome to your opinion. But doesnt mean its correct. There is always a way to get programing if you try hard enough or have friends that work at the dealership.
You are correct.
However I did try.
I know the owner of the dealership very well.
His son (now new owner) once dated my daughter.
The shop Forman has been a friend for over12 years, I do programming and work with him on a different model.
I also know the tech that does the programming work on all the cars that go through their shop.
I don't believe they would all lie to me.
As I also said, the Fiesta ST does not have the camera wiring, so you will need buy a harness.
You could of course wire it yourself but then you are not using all factory parts.
The camera, hatch handle, hatch release button, and the two harnesses are all available from Ford.
Then I guess, hacking the system is a viable factory part.
Please know too that the Sync II system in the Fiesta is different than most other Fords.
I did look all this up before installing mine as I like to use the factory setup as well.
I am not trying to argue with you.
Using ALL factory parts is NOT a plug and play, it will take a bit of work.
And it still wont stay on all the time, as this topic originally started.
Anyway good luck in your endeavor I really do hope you can make it work.
This would provide another option for those that want to add it.
Dave
