I support you're ideas Duane. We need to do this now while the community is growing and the aftermarket is young as many more products will come out. [emoji106]
Thanks!
As a short and related-but-off-topic example, when Razorlab was with us, he and I were actively trading and comparing some logs based on setups. One of the items we were analyzing was the FMIC, where he had the J-Line and I had the Cobb. It was very easy to discern a difference between the two by looking at the data because we both knew what we were doing, logging, and looking at (albeit, he was significantly more experienced than I due to his extensive tuning experience). Without a doubt, the J-Line outperformed the Cobb unit by a few degrees.
I had to accept the fact that his FMIC outperformed mine, and I was perfectly ok with that because that data comparison did not exist until we did it. Would I have made a different purchase with that info? Maybe, maybe not. Both parts have their pluses and minuses, and in no way was the Cobb unit 'bad' as the difference was only ever around 4 degrees max. But from that moment on there was a baseline with legitimate and comparable data for which others could build on or add to regarding FMIC's (well, there was until it got deleted). It made a very clear example to be able to say 'x outperforms y' or 'y is a complete bolt-on but you give up a few degrees of cooling compared to x for that convenience'.
Tl;dr-We're behind the power-curve (pun intended) at being able to accurately answer the OP's question. That's up to us, as a community, to either begin to collect and analyze the data or to continue to just try and guess. It's easy for a vendor or manufacturer to tell us how awesome their product is and why we should give them our money, but it's up to us to determine just how accurate their statements/claims end up being when the rubber meets the road and to spread that information accordingly.
Anywho, [MENTION=1629]speed racer[/MENTION]-I see you're in Smyrna. Are you going to have Injected do your tuning?
