If it's doing it on both tunes then you can rule-out the tune, and if it's across the board and uniform then you can rule-out mechanical looseness. The fact that you say it's uniform and repeatable means that you have something wrong with your fundamentals-fuel, air, or spark. Off the top of my head I can't think of anything else.
Verify your plug gap (I stay between .026-.028" though the factory manual calls for .031") and compare your boost/afr/airflow mass measurements along with your fuel rail pressures between your recent logs and the last-known good ones. Obviously you'll want to pay more attention around the rpm range that the knock develops, but looking outside of it can give clues as well.
