Thread Starter
#321
Thread Starter
#321
Fun fact. Unlike gear or motor oil, it's ok to overfill coolant beyond the MAX indicator. I recently did this after installing the 180 thermostat, flushing the cooling system and bleeding air out. I wanted to make sure I was not going to run low on coolant while out on the road in addition to carrying gallon in the rear hatch.
First the built in filter and now I discover there's a safety bleed that built into the reservoir in the event the coolant cap has failed or overfilling beyond what the system can handle. I'm really finding appreciation for the OE coolant reservoir.
This is my current coolant level, it hasn’t gone down and it's perfectly fine. IMO, it's better to have a little more coolant than not enough. Kudos if you can see the safety built in.
ps. Bleeding the system is ridiculously easy on the FiST and even easier with the Mishi radiator bleeder valve.
