Can't say enough good things about Danny Check, the owner of TB. I had some reservations about the traction bar and clearance with my charge pipe. I think MAPerformance makes the biggest, most "in the way" hot side charge pipe. I gave him some dimensions and he felt it would fit. Well I ordered the traction bar and crossmember brace (replaces the two stock braces that aren't connected), and went with Pierce for the rear torsion bar, as I like the supported and beveled mount point better with Pierce. The advantage with TB is the low profile their design has. My shipment came with a personally signed letter which was a nice touch. The black textured paint and parts themselves were finished well and the packaging was well padded with bubble wrap. No dings or issues.
Well I installed the crossmember brace no problem but as others have said, the a arms are a bit of a pain. I used an impact to loosen the bolt enough for my breaker bar. Taking both bolts out is a no no, as it causes the holes to get out of alignment. Some of you may have read about me modifying my MAPerformance charge pipes to fit with the DHM race intercooler. I tested fitment the traction bar appeared to rub. I cut down and cleaned up my charge pipe a little more to see if it would seat a little higher into the turbo inlet. I was about to install the bar with a small corner touching the charge pipe. Unfortunately this made my car vibrate like crazy.
I let Danny know, who assured me prior that he would refund me fully if it didn't fit. Well I asked about return shipping after showing the spot where the bar rubbed. He straight up refunded me the cost of the bar with no return needed. This is a great company! I definitely wouldn't hesitate to buy from them again, and I did some observations with both parts prior to removing the traction bar. The crossbar brace alone greatly reduces flex from the front. With the traction bar added it felt like it was on rails and with no wheel hop, I felt like I lost power because it was so fuss free. I'm definitely keeping the crossbar brace.
I wanted the TB stuff to work because I feel it's much lower profile than Pierce's 4 or 6 point brace. After the fitment issue, I purchased the 2 point Pierce brace. I'm hoping it won't rub, otherwise I'm looking at replacing my charge pipe.
Bottom line, if you want to stiffen the car and reduce roll, while not compromising any real ground clearance, I'd recommend the TB traction bar and crossmember brace... At least if you don't have the MAPerformance charge pipes. TB really stands by their products and I'm keeping my eye out for future stuff simply because they have such good service... Free fast shipping too!
