Installed the Koni/Eibach setup over the weekend. I just want to quickly add my impressions. After 2 days of commuting i can agree this setup is floaty. I just don't have the confidence in the front end i did with the OEM stuff. Also, it's bouncy. Not terrible but definitely noticeable. Nothing that makes me hate it though. I still prefer it over OEM. Very comfy but still sporty. I have yet to install my bracing (2 pt and rear torsion). I'm hoping the 2pt settles the front end a bit more but i'm not expecting miracles.
What i do hate is the noise. The front is quite most of time but it does groan on certain bumps and while rarely, i get a clunk sometimes. The rear is insanely noisy. Just squawks and moans over any bumps. Sometimes it even sounds like a clunk. I checked the shocks and they're tight so it must be the coils touching.
After much googling it seems to be common issue. The cure for many was coil tubes or isolators. Pieces of hard rubber that wrap around the spring coils preventing them from making direct contact with each other. I called up Eibach and they are sending me sets for the front and rear for FREE! Tonight i'm getting the rear up and greasing the springs. If the sound changes at all then the coil tubes will be the fix.
I'll definitely be rechecking my install this weekend before doing the bracing.
And here's how she sits. I'm diggin it so you know i'm gonna find a way to shut it up
Ok, first let me apologize for the super long post...
I bought these from LilPartyBox (thanks man!) since I was looking for a better ride for future road trips. Went to FL from CA and back earlier this year and while stock was manageable, though fairly annoying, on the main highway most of the time because it was usually maintained well, a few side highways gave some very uncomfortable surprises to say the least.
Unfortunately I just saw this thread or I might have saved some time (thanks guys for the bumps or I probably never would have seen it). I had the Koni/Eibach installed and got the same issues except a lot of noise in the front with little to no noise in rear. Mechanic recommended using oem shocks with eibach springs in front only. This actually felt great! Only complaint is I heard some slight barely noticeable thunks on larger dips in rear. Came back for that issue and he said I should try oem shocks all around with eibach springs.
Decided to go that route but the ride was significantly worse with only a slightly better ride than stock (Felt great on smooth roads though, perhaps it might not be bad for the track or those who drive in areas with better roads, but anything worse than minor bumps will wear on you quick). Did feel slightly better performance wise but I wouldn't want to spend the money for it brand new since it wasn't really a significant difference (Actually it may have been significantly better but I was just disappointed from losing the previous ride quality that I really didn't care so much). I liked it much better with the koni shocks in the rear on eibachs. Maybe the rear is stiffer or something but the Konis made a huge difference on the rear. So much so that I'm willing to settle with some very minor clunking on large dips. Also it seemed to work well with stock shocks on eibach springs in front. Made me want to drive faster because ride is so smooth and tires seem to be planted more all around because they aren't bouncing.
That said I've noticed a small caveat with this setup (Koni/Eibachs rear and oem shocks/Eibach springs front). Noise has been virtually eliminated except slight occasional clunk on rear on large dips especially if going a bit fast. Other issue was on bumpy highways only, ride is somewhat bumpier than usual (not bumpier than oem though or other previous setup) when traveling faster than 75ish mph...
I'm in LA so I'm not talking back road bumpy, but I think those who drive in urban cities may be able to relate. It has been annoying enough to make me slow down (ha, maybe this is a good thing), but I thought it would be worth noting. I think I should reiterate that this is my experience only on the bumpier (read bumpiest) urban highways which unfortunately I have to use on a daily basis. Driving on other highways with typical normal wear with this setup is awesome and I've found that my mileage has unfortunately been dropping by a few mpgs, but my grin has widened by a couple more inches. This setup seems to make my right foot weigh more or something...
After reading this thread though, I'm considering trying the konis all around with oem springs. I hadn't thought about it before but I suspect that this might provide the best combination (without me having to purchase other springs), except for perhaps losing the dropped look. Yes, unfortunate but for me it's not a deal breaker. I may do that next weekend and let you guys know. That said, if the dropped look were more important to me, I'd still be happy with this setup overall.
Sent using Tapatalk
