Installed the Koni/Eibach setup over the weekend. I just want to quickly add my impressions. After 2 days of commuting i can agree this setup is floaty. I just don't have the confidence in the front end i did with the OEM stuff. Also, it's bouncy. Not terrible but definitely noticeable. Nothing that makes me hate it though. I still prefer it over OEM. Very comfy but still sporty. I have yet to install my bracing (2 pt and rear torsion). I'm hoping the 2pt settles the front end a bit more but i'm not expecting miracles.
What i do hate is the noise. The front is quite most of time but it does groan on certain bumps and while rarely, i get a clunk sometimes. The rear is insanely noisy. Just squawks and moans over any bumps. Sometimes it even sounds like a clunk. I checked the shocks and they're tight so it must be the coils touching.
After much googling it seems to be common issue. The cure for many was coil tubes or isolators. Pieces of hard rubber that wrap around the spring coils preventing them from making direct contact with each other. I called up Eibach and they are sending me sets for the front and rear for FREE! Tonight i'm getting the rear up and greasing the springs. If the sound changes at all then the coil tubes will be the fix.
I'll definitely be rechecking my install this weekend before doing the bracing.
And here's how she sits. I'm diggin it so you know i'm gonna find a way to shut it up
