So, over the last few days I've done many things with my Fiesta. One of those things include upgrading from the stock struts/shocks to Koni STR.T. Allow me to preface this: I chose STR.T (orange) over Sports (yellow) simply because I don't require the range of tunability they give. I feel that a lot of us who primarly DD this car won't need Sports, especially from the financial factor. Keep in mind that I'm not an expert, but I am an enthusiast and I like to think I know what I expect from my car. So, as with anything in this life, take this with a grain of salt.
Now, to begin I'd like to quote user mpfannen (original link from the .org:
This is the information I read that lead to my ultimate decision to choose upgrading struts/shocks instead of coilovers. But, I already had it made up in my mind that I wasn't going to lower the car. Had Koni or any others not developed anything, I would have gotten coilovers and set them as high as possible. The slammed life I lived with my Genesis Coupe left a bad taste in my mouth. Anyway, mpfannen's input is very relevant. The only point I have to add is that it would seem that Koni has changed the formula a bit as my STR.Ts have the ABS bracket, and no zip ties were needed.
For my personal impressions:
Pros:
Cons:
Tips&Tricks:
When doing the rears, do one side at a time. You'll thank me because it's not IRS.
Hi everyone, I'm a new member/old lurker and owner of a Fiesta ST (FiST). Quickly to the point, I have been working with Koni NA to develop a set of shocks for the FiST as I like playing/Tuning/Racing many of my cars. I felt the stock suspension is great on the car but not a fan of the unstable rear end on course or when driving to the limit. Long story short, I wanted to start working on a proper suspension design without going all out on high end shocks as with my other cars. We started with fitting the STR.Ts (Streets) and moved on the the Sports (aka Yellows, Single Adjustables, Etc) which just arrived for some beta testing! Koni had my car to test for a week and came up with some interesting findings Here are some notes from the development to date...
-Both struts are different lengths than the regular fiesta, so different lengths/customizing the existing Fiesta shocks were necessary but "may not be needed."
-Bump/Compression (Low Speed) of the OEM Fiesta ST shocks was approx 4x that of the STRTs and over dampened according to the techs at Koni.
...I complained of a lack of grip from the rear of the car when making fast transitions and they said this helped with overall grip.
-Rebound (Low Speed) is much higher in the STRTs, but I didn't get an exact amount. Konis tradition of lower compression and higher rebound out of the Sports have helped my cars handling in the past, and I generally tune much more with rebound > compression anyways.
-The weight/bracket added to the OEM strut, weighing approx 1 lb is not included. This is also found on the Focus ST. Koni believes this is Ford's attempt to correct some brake noise, acting like a counter balance weight, but didn't cause any issues with it gone during testing.
-Ride quality is much better despite the higher rebound and lower compression.
-The rears are plug & play to the stock Fiesta Koni units.
-The fronts have no mass damper (like the ST OEs and all other Fiestas with 17" wheels)
-The ABS bracket is different (see picture) and requires a zip tie or custom bracket to hold the ABS line in place.
-The elimination of the ABS bracket and mass dampening weight is the only reason Koni may decide to not list the ST as an official application since brakes are a safety device and thus create a potential litigation risk is anything is altered from stock system.
My plans with the FiST is to continue using it as a daily driver and occasional track day/hpde/autocross when my other cars are not in competition. I feel the car is too nice of a commuter to take development any further, and ride quality will be compromised after going any stiffer, whether by shock tuning, springs, bars, or mounts, etc. I'm not acting as an official or giving any official statements from Koni, but sharing the info given to me that Im allowed to pass on. At this time, Koni plans/planed to release the STRTs and single adjustable sports for the regular Fiesta, but not for the ST. However, the valving may end up slightly different and these Sports/Yellows and STRTs should also end up working on the STs. Once I have the opportunity to switch out my STRTs with the Sports, I will do a side by side comparison with pictures and measurements and include the OEM struts/shocks.
Pros:
- Easy install (not quite related to the Konis, but slightly relevant).
- Ride comfort improved over OEM at all speeds.
- More connected sensation with the road.
- Apparent reduction in body roll.
- Awesome color.
Cons:
- Have to buy them.
Tips&Tricks:
